Create dowel hole between draw front and counter front|Forum|WOOD DESIGNER
OfflineHi Patrick,
For the moment I believe this is the best approach.
I recognise this is not the easiest application in the software. I believe this is being reviewed moving forward.
OfflineHi Isaac
So, I have tried both methods, the first as it has 2 different datums with the rules means that any change in thickness of the materials for the drawer sides moves the hole so i would have to go in and correct every time I use it which is a bit of a pain.
As you said for the second method as you said this is impacted by the drawer clearance, which is less likely to change but then if not done a routine basis would result in changes being forgotten.
So would prefer the first method due to routine, but if you can think of a another way that we could maybe use the internal zone of the drawer or something like that, but I cannot think of a way of doing that. My drawers have overpassing sides and the the fronts and backs are rebated into the sides, bases are under passing the sides (grooved) and overpassing the counter frontage.
If you have any other thoughts please let me know
Patrick
OfflineHello Patrick,
Let me know if you need a more specific example for your specific method of manufacturing.
OfflineHi Gents.
I was trying to do an alignment hole between the drawer front and the counter frontage so that we can insert a short dowel to align the two correctly and speed up the assembly process, but I cannot work out how to do this. Can this be done and if so can you send me a video on how to do it?
Patrick
2 Guest(s)
