CREATING CABINET GLASS DOOR|Forum|WOOD DESIGNER
Forum Posts: 2091
April 12, 2023 - 9:15 am
I don’t have a perfect solution,
The first solution is to make Multiple drawers, but this generates several facades to assemble which seems to me to be not very functional, and a source of error
Multu-drw.pngImage Enlarger
The second solution is to add Nil shelve  with fixed distance from bottom for example at 250 from bottom add Built-in drawers on top zone, with Nil frontage, without Slack in depth
With multi click, select both zone to add Applied (overpassing) drawer
Fixed distance, is very important to edit positioning rules according drawers,
This solution may seem more complicated but it takes less than 2 minutes
April 12, 2023 - 3:21 am
HELLO, here is the spec from Hettich product. with a maximum height of 186 and 300mm in width. I’m struggling making these type of kitchen drawer into stacking drawers like the reference i sent to you.
since the pdf file is larger than maximum allowed file, so i can get you the link to the product type
https://shop.hettich.com/no_EN…../p/9150398
Forum Posts: 2091
April 11, 2023 - 8:22 am
Can you provided product data sheet in PDF,
April 11, 2023 - 5:30 am
HELLO, COULD YOU HELP ME BUILD THIS TYPE OF DRAWER?AffinityBasePullout-1.jpgImage Enlarger
April 8, 2023 - 3:01 am
THANK YOU, ALEX
Forum Posts: 2091
April 6, 2023 - 7:44 am
PolyBoard is not able to handle metallic profiles
the best representation I could get would be with an assembled element
metal-doors.pngImage Enlarger
April 6, 2023 - 4:01 am
HELLO!
I need to design cabinet glass door using these frame as reference. can you help me build this one?H7b8e07e24ed941a8a83d358c7aa498ccg.jpgImage Enlarger
Thank you!
Most Users Ever Online: 704
Guest(s) 130
brendan kavanagh: 198
Conor Devoy: 158
Zaheer Abbas: 152
Patrick Maylor: 108
Emmanuel Sacco: 106
Blake Simpson: 104
Nathan Bruton
Michael Okyere
Timo Pitkänen
jose andres durango medina
Dag Lislerud Midtfjeld
Rejmond Islami
juan cabezas
Michael Dyer
ALEJANDRO PALACIOS RODRIGUEZ
David Filiba
Topics: 2697
Members: 463
