Custom Macro|Forum|WOOD DESIGNER
OfflineHi Rafal,
This is only the sorting of the machine code in the output file.
To add custom macros you have to apply them in the Structures>Inner tooling command:
This will load and apply a macro from a file you have written for your PP.
The file location is set in Tools>Folders>Parameters:
The macro instructions will be added to machine code in the position defined by the PP sort option:
In this case the macro instructions will be machined after all the other operations.
Hope this is helpful,
Guest(s) 28
© Simple:Press —
