Customizing face frames and saving to methods |Forum|WOOD DESIGNER
April 15, 2019 - 12:41 pm
Hi Nigel,
Here’s a little video:
Hope this is helpful,
April 14, 2019 - 6:46 pm
I’m still not getting it, could you do a step by step to how you got to the face frame and door so I can follow it.
Nige
April 9, 2019 - 7:38 am
HI Nigel,
In the Properties menu, click the “+” External Zones:
external-zones-010.jpgImage Enlarger
external-zones-020.jpgImage Enlarger
Note that you can set these as included in the cabinet dimensions (inner) or outside ie. added to the cabinet dims (outer).
cheers,
April 8, 2019 - 11:15 am
How do I create that external zone to start with!!!!!!!!!!
Nige
April 8, 2019 - 10:50 am
Hi Nigel,
You have to create the external zones and add double backs at 0 from the front.
Then set the double backs overpassing to the carcass panels.
Over lapping values can be set to make the frame sit correctly on the carcass, but it will be necessary to adjust manually the door and drawer slacks as well as the rail lengths. If you can set up some standard configurations all this can be automated using sub-methods.
I attach an example.
Hope this helps,
Cheers,
April 8, 2019 - 10:17 am
Hi Ness
This didn’t take long, I’m confused how do I get the face frame and doors on the front? do I still have to use the double back method?
Nige
April 8, 2019 - 9:34 am
Hi Nigel,
Can you send me you TeamViewer id and password?
Cheers,
April 8, 2019 - 9:15 am
What do you need from me to connect?
Nige
April 8, 2019 - 7:35 am
Morning Ness
9.30 would be good
Nige
April 8, 2019 - 5:04 am
Hi Nigel,
No problem, what time would be convenient for you?
Cheers,
Guest(s) 38
brendan kavanagh: 227
Emmanuel Sacco: 196
polyjohn
Maxime Marengere
everslyjoinery
Topics: 2903
Members: 539
