Customizing face frames and saving to methods |Page 2|Forum|WOOD DESIGNER
April 7, 2019 - 3:26 pm
Hi Ness
Could we do it Monday morning?
Nige
April 4, 2019 - 2:51 pm
Hi Nigel,
Best to do a quick TeamViewer session to sort out your config.
When would you like to meet up?
Cheers,
April 4, 2019 - 9:02 am
Hi Ness
Could you help please, Ive just installed 7 but cant get the quick design toolbars up, I look on the forum and done as you have said to Jan and still no joy, I’m going to be out on site fitting a kitchen today so wont have be able to get back on till tonight.
Nige
March 27, 2019 - 6:35 pm
Thanks Ness
March 23, 2019 - 6:51 am
Hi Nigel,
To print the inside sizes of a cabinet;
In cabinet edit mode,
– make sure that View>Dimensions is on,
– click in the volume to show the inner dims,
– click right and in the context menu select “Permanent Dimensions”
The inner sizes will be displayed permanently, even when you  print the drawing.
dimensions-permanent-example.jpgImage Enlarger
It’s easy to set up a fitting link for but hinges just use a groove in the hardware setup.
but-hinge.jpgImage Enlarger
and apply as normal.
but-hinge-3d.jpgImage Enlarger
March 14, 2019 - 3:11 pm
Hi Ness
When you build a cabinet and you put shelves in it, how do you get a print out with the measurements to show where to place them?
Nige
March 14, 2019 - 10:24 am
Hi Ness
Is it possible to make a fitting link for butt hinges?
Nige
March 11, 2019 - 7:46 pm
Thanks Ness
Nige
March 11, 2019 - 11:26 am
Hi Nigel,
The way to do this is to split the inner panel into 2 panels before applying the door structure.
Once the double back is framed select the inner panel and use the “Surface split” command to make 2 panels.
Then apply a framed structure to each panel:
face-frame-with-double-doors.jpgImage Enlarger
If you add a negative slack to the surface split it will give you the overlap necessary for the rebate:
face-frame-with-double-doors-overlappin.jpgImage Enlarger
March 11, 2019 - 10:53 am
Oh and the doors will need have 10mm overlap so they can have a rebate down the center so no gap when shut.
Nige
Guest(s) 23
Topics: 3003
