cut out |Forum|WOOD DESIGNER
OfflineHi Caroline,
I make this video,
hope that’s helpful
All the best, Alexandre
I’m not sure I understood correctly but here is my interpretation
With inner tooling for first unit
You can select side and choose to copy the structure, then past it to another side.
For the second, you want the back of the cabinet to be 400mm from the front, right?
you can use double back instead of first back
OfflineHi
I have attached units
1st one is sink unit – we need to cut out a section on left and right gables only at the top dimension of cut is 45mm down by 18.2mm from the front of gable
2nd is single oven unit – the internal at the top (400mm) is different from the bottom (500mm) how do I put back on the top to sit on the fixed shelves that are 400 deep
hope this makes sense
Thanks Caroline
