HI Stu,
Sorry haven't been able to get to the forum to confirm this meeting.
I'm OK for next Tuesday but would you be OK for 8:30am 18:30pm your time?
Best,
December 7, 2018
Hi Ness
As we haven't heard back we presume our screen share session will not go ahead today.
Can we reschedule for next Tuesday 2nd of June?
I believe you are in France which is 10 hours behind New Zealand were we are based so best time would be 8am your time being 6pm NZ.
If you can please confirm date and time
Dave
December 7, 2018
Hi Stu,
Setting up you post processor to export the correct data to Enroute depends on the way you have set up Enroute to process your DXF import as well as if you are processing single or double faced parts.
This is a bit complexe without looking into the details so I'd suggest we set up a quick screen share session to look at your configuration.
Would you be available for Tuesday morning 8am-9am?
cheers,
December 7, 2018
OK thanks i will wait to hear back from Ness
What about Enroute to Eazynest where the division is nested wrong side and wanting to drill holes all the way through where we have had to image the panel and adjust drillings manually on Eazynest. Is this a setting on Polyboard where left or right hand has to be specified somehow or Enroute/Eazynest issue?
Dave
We have an issue with some wardrobe units we have just created where the sides seem to have increased by 6mm in height and depth (width) on cutlist compared to actual? see attached cabinet where LH & RH sides should be 1850x450 but cutlist have them at 1856x456.
Also we have issues with division drilling when Entrouted to Easynest where the division is nested wrong side and wanting to drill holes all the way through we have had to image the panel and adjust drillings. Is this a setting on Polyboard or and Enroute/Easynest issue?
dave
