Cutting Holes Into Walls|Forum|WOOD DESIGNER
Tom Jackson
Forum Posts: 142
April 11, 2023 - 12:36 pm
Hi Alex,
Of course, I knew it was something as simple as that. Appreciate the advice.
Cheers,
Tom
April 11, 2023 - 12:25 pm
Instead of applying texture files, you can use 100% transparency.
wall.pngImage Enlarger
Tom Jackson
Forum Posts: 142
April 11, 2023 - 12:05 pm
Hi All,
Typically, I use textures to add doors to the wall function, like the attached image. If I can’t find the appropriate texture, a hole in the wall will do. How do I cut a hole into the wall instead?
Patio-Double-Door.jpgImage Enlarger
Many Thanks,
Tom
Guest(s) 55
brendan kavanagh: 236
Emmanuel Sacco: 210
Zaheer Abbas: 201
Tom Jackson: 142
Rooms Made Simple: 132
MobLux
Valentin Zarzara
Kendal Anderson
Sarah J0hnson
Andreas Nygårds
Nicolas LEBRETON ROOST
Luka Savić
Lee Gent
A S Brighton
Tobias Briander
Topics: 3062
Members: 602
