Cutting lists|Forum|WOOD DESIGNER
OfflineHi Terry,
The best way to export the cutting lists in PDF is simply to install a PDF printer like PDF Creator and then print the workshop document using the PDF Creator.
All the best, Ness
Hi
Has anyone got a quick method of exporting the cutting list to a simple format such as PDF for emailing to a supplier/cutting service.
I could be missing something and Ive watched the video to export to excel etc but thats seems like alot of work for such a simple task.
Had a delivery today from a cutting list that Id manually typed out and I had made a mistake in typing the email so got a couple of parts delivered that were incorrect. Very annoying.
What method do others use.
Terry
Guest(s) 37
© Simple:Press —
