Door feature inside resize to inside cut on cnc |Forum|WOOD DESIGNER
Hi Carlos,
Sorry but there is actually no way to make the inner tooling change size when resizing the cabinet.
You will have to do this by manually editing the inner tooling.
With all I learn on the program i make a upper cabinet and make 2 doors with glass on the center of the doors i make it with internal tooling. I like to now if is possible to make it wen a change the size of the cabinet the doors keep the changes on the width on borther doors. The profile to make the internal grove on the door and the keep the 2 internal profile to cut on the cnc with vectric ?
the doors can be resizer parametric with the cabinet? if you change the dimentions the feature are gone
The door i like to make it on plywood with internal grove for the glass making a pocketing inside and cutting the internal part of the door to edge banding inside and outside of the door of plywood. to cut it on vectric on a cnc .
the is any other way to do the internal grove for the glass inside of the plywood to resize all the feature with the cabinet
thanks for you time!!!
