Door fittings relating to fixed shelves behind the doors|Forum|WOOD DESIGNER
N rules, or non-priority panel depending the Underpassing panel
P rules, or priority panel depending on the overpassing panel
after add fitting with max distance , you are able to edit position (positive value to the bottom, with standard conventionnel rule),
like in this video you are able to move left and right fitting if using the same rules (in your cabinet joined you used first as N and second as P)
or unactive by uncheck “Active” on left of moving value (at 1 minutes of video),
OfflineHi Alex
Thanks for your response. I think I already have those three hinges in my library (there three duplicates with (*) at the end of the name now). I just tried to avoid 3d accessories to not make the projects too heavy, but I guess it’s easier to catch if parts are coliding with the 3d accesory active. How would I go about moving the mid hinge manually, when the total three hinges are put in place with the max distance rule? Change the rule, or can I change them individually after the rule?
Cheers, Oscar.
OfflineHi again Oscar,
Sorry, but the anti-collusion system is only available with regular drilling and the attachment of doors and shelves to regular drilling.
(Lock to regular drillings)
explain and video from this link
in your case, they will have to be moved manually
I have joined in xml, blum hinges with 3D accessories for better control, you can restore them into your libraries , after opening fitting libraries select “Import”
once restored, you can find them in the Blum>Doors subfolder
OfflineHi again,
I’m trying to put some doors in a tall cabinet. Behind the doors I have some fixed shelves and drawers. I noticed that if I moved the fixed shelf to where the hinge of the door is, it doesn’t move the hinge automatically – I’m guessing that there is a rule somewhere to get it to take into account, if the fitting collides with another part?
I’ve attached the cabinet I’m working on.
Best regards
Oscar
/Heimwood
