Door style. |Forum|WOOD DESIGNER
Door style.
December 12, 2018 - 9:10 am
Hi Justine,
You can make frame and panel doors using an “assembled” door structure.
Click the door and go to Structure>Edit>Assembly. You can then set up a shaker style door with mortise and tenon frame and panel:
shaker-door.jpgImage Enlarger
Justin Lahaie
Forum Posts: 8
December 11, 2018 - 4:10 pm
great! thanks. Also if i want to change all doors and drawers to shaker style instead of slab how do i do that?
November 30, 2018 - 6:23 pm
Hi Justin,
There are 2 ways of changing all materials globally, either using QuickDesign materials or changing the manufacturing method.
Video  “14. Changing your design using the Quick Design Libraries” on this page:
shows how to change the design if you have used QuickDesign materials.
This is a quick and easy way to play with different material design options.
Otherwise you can change the Materials sub-method.
To do this go to Libraries>Sub-Methods>Materials Style
materials-submethod.jpgImage Enlarger
Here you can change all the panel types that are assigned to different parts. However note that to update all cabinets in your project, to you have to select all the cabinets before you apply the new style.
Hope this is helpful,
Justin Lahaie
Forum Posts: 8
November 30, 2018 - 12:08 pm
Is there a way to change the door style and or materials used throughout a whole project in one shot?
Guest(s) 31
