Doors both built in and applied global + sliding pocket doors|Page 2|Forum|WOOD DESIGNER
September 29, 2021
Thank you for that fast response 🙂
I can see that all of my images of the actual furniture wasn´t uploaded. Now when I try to upload I get a message saying the files are to big. I have resized them, but it still wont work. I have created links for them, so you can see:
https://ibb.co/WsGG0TD
https://ibb.co/Kz6m22m
https://ibb.co/HBGk5BV
https://ibb.co/MpGYvPF
https://ibb.co/k2pvKvN
https://ibb.co/vX6vNbW
https://ibb.co/s1b3Hkx
https://ibb.co/Rc2BsZy
https://ibb.co/vPZZ1Gc
https://ibb.co/M2Wb3wt
Hi Marianne,
I will look over this information and reply to you soon.
Can you please attach the cabinet file you have taken a photo of below?
I have a couple of questions regarding doors:
1.
Is it possible to “hack” the Polyboard-system a bit, to make a version of both built in and applied global doors? Where the doors are built in (+inset with a slack in depth 30 mm) on the sides and bottom, but where it overlaps the top-panel with 15 mm. Like shown in attachments.
2.
Also, we want to integrate a type of pocket-door, where the doors slides out and down under a fixed shelf inside.
The concept is old/quite easy, but difficult for us to integrate to the machine. My thought is that we can do this more easily on the vertical divisions/side-panels but not quite as easily on the door-sides.
We have an old furniture as guide to how we want it. And attached are some pictures and technical information, to vision it.
As you can see the door it self has a groove that is connected to a tennon in the sidepanels/v.dividers, and the side it self also has a groove that is connected with a different tennon that’s attached in the back/underside of the door. The groove on the door also has a plastic-channel/track, but the groove on the sidepannels don´t have any “coating”. Everything slides very nice and smooth, so this works very good.
(since we will have a fixed shelf I have X-ed out the fittinglink to the shelf with a yellow X. Don’t mind this part. )
We are not sure if we can find exactly the same type of hardware (tennon, plastic-channel/track) as used here, therefore the dimensions maby need to be ajusted. Do you think this is a type of fitting that can be integrated ? Ee have the Homag Drillteq 200. So I suspect the door-groove will be a problem, and maby needs to be done manual.
But maby the panel-sides (both vertical division and leftside/rightside carcass) can be done in the Homag ? I really hope so.
Kind regards
Marianne Hagen Olsen,
Snekkerfabrikken AS
