Downloading and importing Blum 3D fittings into Poly – how can it be done?|Forum|WOOD DESIGNER
OfflineHi Ben,
For all 3D accessories import process you can read this page > PolyBoard handles, 3D accessories tutorials.
Sketchup plugin mentioned in the article is available from this below and according our Sketchup version.
Please never import in PolyBoard dxf with over 2000 3D faces, this is indicated at the time of Sketchup export.
Kind regards, Alex
August 19, 2025
OfflineHi everyone,
I’d like to ask where you usually download Blum 3D fittings from.
So far, I’ve found some here:
They are available in two formats: Collada and SketchUp files.
I also managed to dowload 3d models from Blum e-connect website in .dxf fomrat, nevertheless i cannot see anything after i import it.
However, I can’t import these into Poly.Could you please let me know how to convert them for use in the system, or if you know of a website where they can be downloaded directly in a Poly-compatible format?
Thank you,
Ben
