Polyboard 7.06a has been released today with a fix for this, the feature is now available again.
Hi
This point will be corrected in the next update which will arrive shortly,
Sorry for the inconvenience
All the best, Alexandre
Graham MacRae
October 26, 2020
When setting up this method the ‘Ignore Links if one of the Panels is Nil’ check box does not appear in the fittings link sub method page. Is there a setting that will make this available or is this possibly a glitch in the program?
I have recently upgraded to the latest version 7.06.
Thanks, Graham
Yes, you can!
But to be easy to use, I think you have to define specific configurations
(example done with only 6 drawers)
1 * Add new drawer preferences
2* Set New Material Style
3* New fitting links
(note this option must not be activated for a nil drawers facades, because Polyboard uses the front to add links)
Now we can add drawers with Nil front
You can find cab for this example attached, in PB7.05B, This is possible when you add drawers, it uses your preferences
Cheers, Alexandre
