I have tried to make a video of the complete installation as clear as possible.
Step A
Installing the drawer casing
Step B
Create fitting between Drawer frontage and Cabinet Side
Step C
Create fitting between Drawer frontage and Drawer Side
*both use rule Unique-Right/bot-0050-p, to start at 50 from bottom frontage
Step D
Create fitting between Drawer frontage and Drawer Side with dowels (for exemple)
using 37-37/200-n to follow drawers side height
You can also watch this series of videos for more explanations.
https://wooddesigner.org/help-.....-hardware/
Hope that's helpful, Alex
February 22, 2021
Can you please attach the planning of the drawer slides or the model you would use for this
Cheers , Alex
February 22, 2021
Hi, i need help with the settings on a plywood drawers in a van shelving unit.
I've added a basic drawer, which looks correct but i don't know about all the settings, so I just need assistance setting up the first one please
The drawer sliding runners are 450mm L x 45mm H x 12mm W
It doesnt want a counter-frontage on the inner box.
Also, need drill points addding to to the drawer and outer box for the runners..
Not sure regarding the inner elements/sub-methods seetings if you can help set it up please.
Can you do me a video/edit the file, so i can use the same settings going forward...
