Drawers needs sides and Corner cabinet advice needed|Forum|WOOD DESIGNER
Tanya Snyman
Forum Posts: 14
March 5, 2024 - 5:43 am
Hi Alex,
Thank you, that helped. I will make my changes.
March 4, 2024 - 3:48 pm
At the start of the design process, it’s very important for me to choose your hardwares
On wall cabinet I see you used standard hing instead of Blum like base cabinets?
hings.pngImage Enlarger
Another point on the angular part, the addition of filler is also a part not to be neglected because there will very probably be a handle which could then hits at the opening.
ang.pngImage Enlarger
For exemple frontage of 445mm on Left and 870mm double doors cabinet to have 30x30mm filler
Hope that’s helpful, Alex
Tanya Snyman
Forum Posts: 14
March 4, 2024 - 3:06 pm
Good day,
I am very new on polyboard and are still watching videos and learning. So I need some help please.
Could you please help me to add sides in my drawers and also look at the corner unit to see if the doors will work fine?
I have also removed alot of the fitting links as we always had someone else help us with Cutting lists and then we would just use screws to asseble the boards/cabinets. It works fine for us, but we do need the holes for the door hinges though.
If you pick up anything faults please let me know so that I can better my skills.
O, we also want to use sliding rails for the drawers, but I have not selected anything there yet.
Thank you in advance for all the help and patients.
Tanya
  • sp_PlupMedia Project1-Kitchen-2.zip(179 KB)
Guest(s) 49
brendan kavanagh: 236
Emmanuel Sacco: 210
Zaheer Abbas: 201
Tom Jackson: 142
Rooms Made Simple: 132
MobLux
Valentin Zarzara
Kendal Anderson
Sarah J0hnson
Andreas Nygårds
Nicolas LEBRETON ROOST
Luka Savić
Lee Gent
A S Brighton
Tobias Briander
Topics: 3062
Members: 602
