DXF Export control|Forum|WOOD DESIGNER
Forum Posts: 1781
OfflineHello,
Yes, you can set this up. I have explained this to you in the following video with an example.
dsdds
Forum Posts: 16
November 12, 2020
OfflineHello.
I was wondering if you could tell me if Polyboard can do this? I am using V carve for our g code generation and would like to have the dxf post processor output the second face files to another folder. That way I can nest all the files without having to filter out the second face copies, and then cut the ones needing the other side to be processed, afterwards. Can I also control somewhere where the second operation is needed or what the software considers as a primary face?
Thank you
Guest(s) 51
brendan kavanagh: 236
Emmanuel Sacco: 210
Zaheer Abbas: 201
Tom Jackson: 142
Rooms Made Simple: 132
MobLux
Valentin Zarzara
Kendal Anderson
Sarah J0hnson
Andreas Nygårds
Nicolas LEBRETON ROOST
Luka Savić
Lee Gent
A S Brighton
Tobias Briander
Topics: 3062
Members: 602
© Simple:Press —
