Edge tape missing in Modify Styles|Forum|WOOD DESIGNER
Forum Posts: 1441
May 13, 2024 - 3:57 pm
Thanks Nadaam.
We have reported the issue to be fixed. Hopefully we should see this updated soon.
Nadeem Lotia
Forum Posts: 56
May 13, 2024 - 12:53 pm
Thank you for the feed back, We are getting by as you have advised, However The “Modify Styles” is a very convienient tool and I hope you can figure out why we cannot see all the edge tapes there. This may also leads to Production errors as the user may never verify each and every panel for edge tapes.
Forum Posts: 1441
May 13, 2024 - 12:38 pm
Hi Nadeem,
Please see attached image. If you access the edge tooling for your doors you will find the stray edge and be able to change it. This should fix the error in your documentation.
I am unsure why this won’t show up in the “styles>edge materials”. I am still looking further into this.Edge-10915-solution.pngImage Enlarger
Forum Posts: 1441
May 13, 2024 - 12:12 pm
Hi Nadeem,
Sorry for the late reply. I am looking into this now. I should reply to you soon.
Nadeem Lotia
Forum Posts: 56
May 11, 2024 - 8:49 am
Attachment 01.JPG showing from where we select command “Modify Styles”
Attachment 02.JPG showing only two edge tapes in Modify Styles->Edges
Attachment 03.JPG showing Summary from Print Preview, here the program shows 3 edge tapes which is correct.
Finally we have attached complete cabinet file used for your study.
Please let us know where we are making a mistake. Why is the third edge tape missing from Modify Styles?
Currently Online: Tom Jackson, LORIN STANCIU
Guest(s) 51
Timothy Bennett
Members: 536
