In the following example element from my current project it seems that the thickness of the edging is not being removed from the panels…
I have a total depth of 627.5, and a slack in depth of 3mm between the doors and cabinet (push to open) when doing the math everything checks out, only if there is no edging.. I have exported a dxf file that measures 589.5….
I have checked the edging material inm the library, and it is defined as being 2mm….
