Edgeband Internal Edge of Panel Structure|Forum|WOOD DESIGNER
Forum Posts: 1663
January 24, 2025 - 11:08 am
Tom,
I don’t have any information for that at the moment.
We are expecting to see a number of major updates throughout the year.
Sorry that I cannot help any more at the moment.
Tom Cleaver
Forum Posts: 166
January 24, 2025 - 11:00 am
Hi Issac,
Thanks for the quick response.
Unfortunately that solution doesn’t really help. Do you have an idea of when this may be solved?
Kind regards
Tom
Forum Posts: 1663
January 24, 2025 - 10:57 am
Hi Tom,
Yes, this is currently a limitation of the Panel Assembly feature.
The only solution we have at the moment is to double the thickness of the edge tape on the external edges of the panel. Although, I do recognise that this is not an option for all methods of manufacturing, so it depends on your set-up.
Thanks for letting us know, I’ll keep you updated with any immediate changes.
Tom Cleaver
Forum Posts: 166
January 24, 2025 - 10:38 am
I am trying to apply an edgeband to the internal edge of a panel structure. These are  the issues I am coming up against:
  • When the structure is either overlapping assembly and/ or has an intermediate cross bar there is no option to apply the edgeband
  • When the panel is changed to mitred assembly the option to apply an edgeband to the inside edge is now available
  • When the edgeband is applied to the inside edge as a mitred assembly it then doesn’t actually apply
I assume this is a combination of a limitation in the edgebanding of a panel structure and a bug when trying to apply.
We often need to apply an edgeband on the internal edge of a panel structure so any help on this would be much appreciated.
Kind regards
Tom
2025-01-24_103212.jpgImage Enlarger
Guest(s) 18
Topics: 3003
