Export Measurements Not Correct |Forum|WOOD DESIGNER
June 15, 2021 - 7:01 am
Thank you Michel,
So much to learn….:)
June 15, 2021 - 6:02 am
Hi Christopher,
You have to check your submethod grooves and oversizing. It has an oversize setting for all panels on 5mm. If you put this to 0 the oversize will be removed. You need to do this for every cabinet in your project via the single cabinet mode
grover.pngImage Enlarger
June 14, 2021 - 10:14 pm
I have just been looking at this again and actually all the export measurements have an additional 5mm on them.
No idea why, if you could shed some light that would be great.
Not ideal really as trying to process orders that need precision, 5mm out could cause a lot of problems.
Obviously it may also be user error which I do understand.
Chris
June 14, 2021 - 9:54 pm
Here you go
June 14, 2021 - 6:19 pm
Hi Christopher
Can you please add your cabinet file to the post so that we can check?
June 14, 2021 - 1:16 pm
Hey guys,
I have just exported a cut list, upon checking the measurement’s 2 of the shelves (These are single panels in their own right) are showing in my diagram as 950mm wide but when I export they are showing as 955mm.
I am not sure why this is happening, any idea?
Chris
2021-06-14-1_LI-1.jpgImage Enlarger
2021-06-14_LI-1.jpgImage Enlarger
Guest(s) 42
