EXPORT TO BEAM SAW NANXING|Forum|WOOD DESIGNER
OfflineHello Lorin,
After our call, I am closing this request.
Please let me know if you have further questions.
Have a great day,
OfflineHello Lorin,
I will schedule in a call and ring you as soon as I have a moment to in the next few days.
OfflineHello Lorin,
I apologise, I am not sure I fully understand here.
Can you please send me an OptiCut file that you are having this problem with? I will look into this.
OfflineHi Isaac, just so i understand the process better:
Currently when we finish a project, when exporting to opticut, it gives us a ‘x’ amount of panels needed.
However, when exporting the cutting list to the beamsaw software, the amount of panels needed is less.
Does the post-processor option eliminate that?
OfflineHi Issac,
at the moment:
in polyboard we go to cutting lists and then CSV/TXT EXPORT. the file we then send to our beam saw. in polyboard when we go to post-processor export, we cannot select any options.
in polyboard under cutting lists, when we choose opticut export, it opens opticut and when we export in opticut and send the file to the beam saw, the beam saw software does not recognise the file.
OfflineHello Lorin,
Sorry for the confusion, I just want to clarify how you are exporting your OptiCut results.
So from what you stated, you are sending your files to OptiCut and running saw optimizations. In your OptiCut, you are not having success with a post processor export, so you are instead exporting to a csv/txt file. When you say exporting to a csv/txt, are you referring to the results export in the following image?
The only option for a specific path of cutting list>CSV/txt is in PolyBoard and not in OptiCut. Instead of OptiCut, are you instead meaning to say PolyBoard?
Thanks, Isaac
2 Guest(s)
