face frame|Forum|WOOD DESIGNER
face frame
October 6, 2021 - 1:03 pm
Sorry, I can’t see uploaded files,
But I understand you can use Surface Split with dimension ( screen “SP” ),
SP.pngImage Enlarger
then set unwanted part  to nil (screen “Nil”),
Nil.pngImage Enlarger
Like this screenshot below
Ext.pngImage Enlarger
All the best, Alexandre
Up-1.pngImage Enlarger
October 6, 2021 - 8:55 am
Hi Alex
The area in green on the attached fills the external zone, I want it to be the same dimension as the rest of the face frame.
Thank you
Dave
October 5, 2021 - 3:32 pm
To be sure to start in the right direction, can you leave me a quick drawing of what you want to achieve,
thanks in advance, Alex
October 5, 2021 - 2:04 pm
How do I alter the thickness of a double back to form a face frame?  I want the external zone to be larger than the face frame, not the face frame to fill the external zone, so I can form a plinth with the face frame sides.
Guest(s) 43
