Face frames|Forum|WOOD DESIGNER
Face frames
April 13, 2019 - 5:08 am
Hi Tom,
I’m actually setting up a suite of methods for making this type of frame, that I’ll be adding to the Quick Design libraries.
I’ll keep you posted when they are ready.
Cheers,
Tom Cleaver
Forum Posts: 166
April 3, 2019 - 1:36 pm
I would like to design cabinets using face frames as shown in the attached drawings. It requires a face frame to be applied over multiple cabinets. It also requires (in this case) the drawer fronts to be offset in the left, right or both sides to accommodate there position in the assembly and relationship to the face frame. For example the left hand cabinet will require a vertical face frame on the left, but none of the right. The centre cabinet will have no vertical face frames and the right hand cabinet with require a vertical face frame on the right, but not on the left. All cabinets will need and upper and lower horizontal face frame applied.
Please see drawings attached and the polyboard model to the point where I am stuck……
Guest(s) 36
