Finger Groove detail|Forum|WOOD DESIGNER
July 18, 2017 - 3:57 pm
Hi Thusitha,
I’m not very  clear on how you are making these but you must have Polyboard Pro to work with bar materials and set up solid wood frames.
drawer-with-frames.pngImage Enlarger
3d-drawer.pngImage Enlarger
With Lite you can only work with panels.
So you can do this:
drawer-3d.pngImage Enlarger
Note that no version of Polyboard will draw the 45° bevel for the finger groove, this has to be added manually.
July 17, 2017 - 5:57 am
Hi!
Please check the attached, drawing.
We need to insert a 2 3/4 inch stripe, in the front, between the two drawers. The top drawer has finger grove at the bottom and the bottom drawer has finger grove at the top.
Then the back panel is to be fixed 1 inch inwards from the edge.
Sometimes we fix back panel in MDF, and the rest is solid wood.
Please advice us how can we do it.. Is it with Polyboard Lite or Polyboard Pro or Pro PP??
Attachments area
Guest(s) 34
everslyjoinery
Members: 537
