Fitting link sub-method and Fitting Rule |Forum|WOOD DESIGNER
Forum Posts: 2100
We don’t have fitting link sub-methods or fitting rules dedicated rules for Lamello ,
But you can easily edit/duplicate/rename sub-methods, select all fittings and change theme in one time,
to change for exemple Cabineo sub-method in Clamex sub-method ,
For Rule you can create classic 0060-0060/0300-n like recommande by Lamello, to start a 60mm from top/front and finish at 60mm from bottom/rear,
then add new link ever step over 300mm between 2 links
Hope this helpful, Alex
Guest(s) 63
brendan kavanagh: 209
Zaheer Abbas: 156
Patrick Maylor: 114
Tom Jackson: 113
arno.s
JP123
Cristian mihoreanu
Jurij Avizen
H
magnus rehn
Stephanie Olaverry
Gustavo Muñoz
Topics: 2757
Members: 479
© Simple:Press —
