Fitting links sub-method is not working properly for some fittings|Forum|WOOD DESIGNER
Forum Posts: 1961
May 30, 2024 - 3:44 pm
This is not an issue, it is because this is not available from Sub-method,
Single door have 4 directions in sub method , Fittings side , open side, left/bottom an right/top of fitting
Double and sliding doors have only 2 directions , fittings sides , it is not possible to said left or right of fitting because you have 2 fitting sides
Kristel
Forum Posts: 8
January 25, 2024
May 30, 2024 - 9:54 am
I’m encountering an issue with fitting links. Specifically, when I apply stoppers between doors and shelf-f in the sub-methods, they don’t seem to activate on the actual module. However, if I add them manually through the “Properties” column on the right side, they do activate correctly. See the video below.
Any advice on how to resolve this would be greatly appreciated!
Thanks in advance for your help.
https://drive.google.com/file/…..sp=sharing
Most Users Ever Online: 365
Guest(s) 34
brendan kavanagh: 168
Tom Cleaver: 164
mark nichols: 162
Conor Devoy: 158
Zaheer Abbas: 132
Blake Simpson: 104
Tom Jackson: 83
Patrick Maylor: 81
roni vilavila
Miryahya Khameneh
mathew moule
Christian Lopardo
Romerworld
Evaldas Gudenas
Petr Břichnáč
Ar Te
Ilie Mihail
GERARDO MARMOLEJO
Topics: 2480
Members: 380
