Fittings links on surface & thickness split|Forum|WOOD DESIGNER
Forum Posts: 1970
February 8, 2023 - 11:50 am
Thank you for the feedback, I missed this point when opening your cabinet.
Rikka
Amsterdam
Forum Posts: 44
November 27, 2020
February 7, 2023 - 2:03 pm
Oh i’m sorry in reading this back I see that it wasn’t clear what I was meaning.
What’s happening is my dowel fittings are being centred in the panel which i have applied a thickness split to, and I was wondering if there is a way to apply the fittings to both panels of the split?
And in walking through this and trying to explain it better I have realised I have the solution. To not use a thickness split and instead just have 2 shelves which touch each other.
Attached 2 images of what I was getting, as well as my accidental solution should anyone else have this in the future:
Screenshot-2023-02-07-at-14.43.29.pngImage Enlarger
Screenshot-2023-02-07-at-14.39.23-1.pngImage Enlarger
Forum Posts: 1970
February 7, 2023 - 12:04 pm
To complete your work, you can select “N” to follow the split side (Underpassing / No priority panel).
Then specify you have surface split, (Green arrow)
If you have enough hings, you can already manage them by selecting the fitting number, move them or deactivate them. ( Pupule arrow)
SP.pngImage Enlarger
Rikka
Amsterdam
Forum Posts: 44
November 27, 2020
February 7, 2023 - 10:08 am
Hello.
I have a somewhat odd (for us at least) cabinet to make and need a little assistance to get it worked out.
A client has requested that we do full height doors, but we need to make the cabinet boxes as 2 seperate pieces due to material size & transport constraints.
My idea to be able to have the door run over 2 cabinets was to build a single cabinet that has thickness & surface splits so i’m still able to build it in cabinet mode and apply the doors across both.
Is there a way for me to have Polyboard put seperate fitting links across the thickness split instead of what it is currently doing where it puts it in the middle? Even just a quick workaround as I don’t imagine it’s something I’ll encounter too much.
Attached is a stripped down version of the cabinet to better visualise what I mean.
Thank you!
Most Users Ever Online: 365
Guest(s) 22
brendan kavanagh: 179
Tom Cleaver: 164
mark nichols: 162
Conor Devoy: 158
Zaheer Abbas: 132
Blake Simpson: 104
Patrick Maylor: 84
Tom Jackson: 83
EIlon Shperber
Alex Pop
Rick48
Hassan Sultan
Carmela Di Sorbo
Telmo Oliveira
Jesus Vergel
eduardo beiza
lucas Lucas Moreno
Topics: 2516
Members: 395
