Front fitting for Legrabox|Forum|WOOD DESIGNER
Forum Posts: 2128
April 10, 2025 - 3:21 pm
Hi again,
Sorry for my English, but please watch this new video for more explain
Hope this helpful, Alex
Ola svensson
Forum Posts: 100
April 10, 2025 - 1:38 pm
And here is the picture of the result…
I need the 3 holes to be drilled with a 10 mm drill and with 13 mm depth.
Ola svensson
Forum Posts: 100
April 10, 2025 - 1:35 pm
Hi again,
Thanks for your reply.
I have now changed this in the methods, but why  is there so many holes?  I only need 3 for the fitting to the front. see attached photo.
Can you please advise on how to make this? When I drilled this in the cnc it aslo makes the wrong depth and uses the wrong drill- how do I change these parameters?
Thanks, Kind regards Ola.
Forum Posts: 2128
April 10, 2025 - 8:16 am
Watch the video
In your case, and after studying your cabinet, you’ll probably only change the drawer submethods,
In my video, you can see what happens if you change only the drawer sub-methods, then only the assembly sub-methods.
When you want to change the height, you have to use the generic methods, because when you want to change the drawers, you have to change both sub-methods.
The drawer box with drawer sub-methods,
the drawer fixing link with the drawer fixing sub-methods.
Ola svensson
Forum Posts: 100
April 9, 2025 - 1:55 pm
Hi.
we are trying to draw a simple cabinet with built-in drawers using Blum Legrabox in hight M and F. Please see attached file.
I can’t see that the third hole for the front fitting on the F height legrabox are created . just the bottom 2.
legrabox C and F use 3 hols for the front adapter. What are we doing wrong to only get 2 of the 3 holes required from the drawers in the library.
Can you please advise on how to solve this?
best regards,
Ola
Guest(s) 38
brendan kavanagh: 227
Emmanuel Sacco: 196
polyjohn
Maxime Marengere
everslyjoinery
Topics: 2903
Members: 539
