full doors on divided cabinets |Forum|WOOD DESIGNER
May 20, 2025 - 8:02 am
Please find a video explaining how you can do this.
Emmanuel Sacco
Forum Posts: 199
May 19, 2025 - 3:58 pm
and by the way your reply was without sound .
thank you
Emmanuel Sacco
Forum Posts: 199
May 19, 2025 - 3:57 pm
dEAR Alex
Sorry for your time because i cant understand why the file i uploaded first was not with the top units .This is the wright file finish.i need full lenghts doors from top to bottom and boxes will be made in 2 parts because i will not get in place .
thank you
e s
May 19, 2025 - 3:17 pm
if you’re talking about “wrd frans 2 drw” please see video
Kind regards, Alex
Emmanuel Sacco
Forum Posts: 199
May 19, 2025 - 1:18 pm
dEAR ALEX
AS ALWAYS THANK YOU FOR YOUR KIND HELP.
I MANAGED TO PUT THE BACK UP BUT UNFORTUNATLY DO NO MANAGED TO MAKE THE DOORS .i EVEN TRY TO GROUP THE CABINET WITH NO SUCCES .
May 19, 2025 - 11:13 am
Hi Emmanuel,
Isaac is away this week, but I’d be happy to help you.
In order to fully understand your request, would it be possible to confirm which cabinet you are referring to? In the case of “wrd frans 2 drw”, after several clicks, it would then be possible to add full-height doors, but the drawers would then be transformed into build-in drawers, so the drawers would also have to be raised, or a wedge added to the thickness to make space for the hinge.
To avoid a groove on the entire height, the back should be recessed from the Top  or from Bottom
Emmanuel Sacco
Forum Posts: 199
May 17, 2025 - 3:11 pm
Dear Isacc
I had this wardrobe design attached  that wish to put doors from top to bottom if possibel.I have a  half back and wish to remove the grove for it were i am not going to do the back. Can you please show me how to do it .
thank yoiu
E Sacco
Guest(s) 25
