grooved panel |Forum|WOOD DESIGNER
grooved panel
brendan kavanagh
Forum Posts: 209
September 28, 2022 - 12:29 pm
Hi Alex and Michel
Yes this has been sorted now i did use the 12mm it worked out perfect thank you again for your patience and time
Thanks Caroline smile
Forum Posts: 2100
September 28, 2022 - 7:45 am
Hi Caroline,
Michel let me know this problem has been solved.
But the best is to use the biggest tool, because with a 4mm tool and if I have seen correctly with a 1m overlap that is effectively 100 passes to do all the work
brendan kavanagh
Forum Posts: 209
September 23, 2022 - 2:06 pm
this is file now compressed i looked at your video still not understanding and some is in french??
TAke a look at my file on vcarve
Thanks CAroline
Forum Posts: 2100
September 23, 2022 - 1:34 pm
for send specific files you need to compress it before upload
zip.pngImage Enlarger
Michel is not available on Friday..
Forum Posts: 2100
September 23, 2022 - 1:32 pm
It is here 😉
Hope that’s helpful
brendan kavanagh
Forum Posts: 209
September 23, 2022 - 1:21 pm
i have sent you file from vcarve how i think it is setup can you take a look it says its taking 12mins to cut the groove 1 depth 3mm and another 12mins to cut groove 2 at 6mm
wont let me upload!!! maybe you are Michel can dial in with zoom
Caroline
brendan kavanagh
Forum Posts: 209
September 23, 2022 - 1:05 pm
Hi Alex
im sorry i dont really understand we use polyline on post processor is that what you are asking??
do i use the 4mm end mill i dont know how to get the 15mm wide groove on vcarve  can you do a video??
i attached the file in previous
Caroline
Forum Posts: 2100
September 23, 2022 - 12:41 pm
Hi caroline,
depending your groove PP setup
More details in my previous post
https://wooddesigner.org/forum…..-on-board/
for 15mm width you need to Output into Polyline to have rectangle to make internal “Profil Toolpath” ,
profile-TP.jpgImage Enlarger
if the diameter of the tool is large enough, or , or ‘Pocket ToolPath”
brendan kavanagh
Forum Posts: 209
September 22, 2022 - 7:07 pm
Hi Alex
Following on from this grooved panel i have attached file but now i want to cut it out in vcarve but we have a 12mm end mill and 4mm end mill how do i set up the cutting in vcarve as the width is 15mm????
can you come back to me asap please
Thanks again Caroline
brendan kavanagh
Forum Posts: 209
September 21, 2022 - 11:41 am
Yes Alex thats it
Thanks Caroline
Guest(s) 53
brendan kavanagh: 209
Zaheer Abbas: 156
Patrick Maylor: 114
Tom Jackson: 113
Monica macias garcia
arno.s
JP123
Cristian mihoreanu
Jurij Avizen
H
magnus rehn
Stephanie Olaverry
Gustavo Muñoz
Topics: 2758
Members: 480
