Grove into a single side of a piece|Forum|WOOD DESIGNER
MITC
Forum Posts: 60
October 19, 2022 - 10:08 am
Thanks for your help Michel.
I can confirm using a surface split, and a full depth mortice and tennon has worked and allow me to remove the central section.
Screenshot-2022-10-19-100728.jpgImage Enlarger
MITC
Forum Posts: 60
October 19, 2022 - 9:09 am
Can you think of any work arounds in the mean time?
October 19, 2022 - 7:41 am
We haven’t forgotten you,
This is a long-standing constraint known to the development team, who are looking to see if they can work around this problem,
without however being able to give a deadline
All the best, Alexandre
MITC
Forum Posts: 60
October 12, 2022 - 3:47 pm
Thanks, we are hoping to take this product to production soon. So it would be good to get it sorted.
Cheers
October 12, 2022 - 12:06 pm
I will ask the development team in a future discussion if this is a bug or a technical software constraint.
MITC
Forum Posts: 60
October 12, 2022 - 9:06 am
I have just found the bug!
If I remove the mortice and tenon joint type from the back of the drawer to both drawer sides, it allows me to remove the central back panel as required.
Screenshot-2022-10-12-090058.jpgImage Enlarger
As soon as I add in the mortice and tenon joint type again it brings the middle panel back in.
Screenshot-2022-10-12-090135.jpgImage Enlarger
Please could this be looked at and a bug fix sent out?
MITC
Forum Posts: 60
October 11, 2022 - 4:19 pm
Presumably that means that there is a bug somewhere in the program that needs sorting?
I will try to redrawer the unit from scratch to see if it still happens a second time or not.
October 11, 2022 - 3:30 pm
I don’t understand why your cabinet won’t let me do this.
cheers, Alex
MITC
Forum Posts: 60
October 11, 2022 - 1:54 pm
That makes sense that it is the nil panel that is not letting the middle section of the back become a nil panel. I put in the nil panel so the 2 vertical divisions are referenced off that so when the unit is resized they still stay spaced around the centre of the drawer.
Is there a different way to place the vertical divisions so when the unit is twice the width (for example) they are still centrally placed and spaced apart without using the nil panel?
We are wanting to design this unit so it can be all custom sizes using catalogue mode.
October 11, 2022 - 1:49 pm
Nil panel in center of your drawers don’t let drawers back to be set as Nil panel too
Nil.pngImage Enlarger
Guest(s) 31
