Hardware Packs|Forum|WOOD DESIGNER
Hardware Packs
MITC
Forum Posts: 60
October 3, 2022
September 19, 2024 - 12:50 pm
Thanks,
That makes loads of sense.
J
Forum Posts: 1970
September 19, 2024 - 12:17 pm
In order to make this more readable, we now indicate the standard overlap value of the box as it is registered with the hardware supplier
“D” for blum, “B” for hettich, “K” for Grass and Salice , In the absence of this information, the recovery value of the min-max value will be indicated. ( rec / ol )
This value is the fixed overlaps value from inner side, (this value is always provided in use with 0mm Baseplate!)
Hinges-1.pngImage Enlarger
X / I is the type of baseplate crossed or inline, and the value 0X is the thickness of the baseplate
MITC
Forum Posts: 60
October 3, 2022
September 19, 2024 - 9:45 am
Thanks, that is a great help.
It still doesn’t explain the X** value unless I am misreading the document, I am also unsure what the D11 value at the end means and how it relates to the geometry.
Forum Posts: 697
September 19, 2024 - 9:15 am
Good morning,
In your Quick Design Libraries you will find a folder called Guides.
This contains a document called PolyBoard Quick Design libraries manual.
This should contain the information you are after. I have also attached this document here.
MITC
Forum Posts: 60
October 3, 2022
September 19, 2024 - 8:54 am
Is there a description anywhere on the naming conventions in the hardware packs? There seems to be some standard but I havnt worked it out yet.
For example, in the Blum pack there are 2 very similar fittings “Blum/HINGE/75T159-X00/app/D11” and “Blum/HINGE/75T159-X03/app/D11”. Looking at the fittings it looks like the X** is the mount plate height?
Is there a document you can share that explains these conventions?
Screenshot-2024-09-19-085118.pngImage Enlarger
Most Users Ever Online: 365
Guest(s) 26
brendan kavanagh: 179
Tom Cleaver: 164
mark nichols: 162
Conor Devoy: 158
Zaheer Abbas: 132
Blake Simpson: 104
Patrick Maylor: 84
Tom Jackson: 83
EIlon Shperber
Alex Pop
Rick48
Hassan Sultan
Carmela Di Sorbo
Telmo Oliveira
Jesus Vergel
eduardo beiza
lucas Lucas Moreno
Topics: 2516
Members: 395
