Help needed setting up regular drillings|Forum|WOOD DESIGNER
Andrew Driffield
Forum Posts: 5
September 19, 2023
March 6, 2024 - 4:39 pm
Thank you Alex, most appreciated all working
Kind Regards Andrew
Forum Posts: 1909
March 6, 2024 - 1:20 pm
Please update to the last 7.10U from download pages
Andrew Driffield
Forum Posts: 5
September 19, 2023
March 6, 2024 - 12:35 pm
Hi Alex, Your English is very good, no problem understanding you,
When I try to load file I am getting a unexpected file format PolyBoard 7.10F I have had this problem before with something Michel sent me,
Thank you for the Video all make sense
Regards Andrew
Forum Posts: 1909
March 6, 2024 - 12:12 pm
Please find attached draft With 2 Extra fitting and 3 Rules
I’m really sorry for my english
And out of video adding Metal structure
Hope that’s helpful, Alex
Andrew Driffield
Forum Posts: 5
September 19, 2023
March 6, 2024 - 9:48 am
Hi Alex,
Please find attached drawings, I have removed my attempts with fittings, we are using 40 x 40 & 80 x 40mm Aluminium slot extrusion with 8mm slots & slot nuts as the internal frame.
Kind Regards
Andrew
Forum Posts: 1909
March 5, 2024 - 3:14 pm
Can you send me your cabinet and hand drawing of our needs?
Andrew Driffield
Forum Posts: 5
September 19, 2023
March 5, 2024 - 12:11 pm
Hi, I have been trying to set up regular drilling in the edge of under passing and overpassing edges to allow bolting to an internal corner without much success and need help please the holes are 8mm starting at a set point and finishing at a different point with 4 additional holes equally spread but on the under passing panel 20mm in from the edge and on the overpassing panel 38mm in from the edge, the panels are 2050H x 1182W, are you able to assist? Thank you Andrew
Most Users Ever Online: 365
Guest(s) 66
brendan kavanagh: 153
Conor Devoy: 146
Zaheer Abbas: 117
Blake Simpson: 104
Robert Coxhead: 74
Patrick Maylor: 73
razvan george tomas
Dennis Nwachukwu
Richard Maursky
sean mcmullan
James Shepherd
matthew fier
JEROME BRIERRE
Zaki Brijawi
Paul Glavin
Girts Martinsons
Topics: 2298
Members: 342
