Help with a few things|Forum|WOOD DESIGNER
August 25, 2014 - 5:10 pm
Yes all good thanks. Just need to sort the grain on a couple of panels thats all. Will post all the jobs from start to finish when compleated in october.
August 25, 2014 - 4:48 pm
Hi Jim,
it’s good to know that it’s all working now.
Are the cutting lists okay for you?
August 25, 2014 - 7:56 am
Hi Ness, I have now got the latest version and its fine! must have been something odd in the old version…Thanks!
August 24, 2014 - 8:37 pm
Hi Jim,
Have you installed the latest version 5.12b?
If not can you download it and try again?
August 24, 2014 - 7:53 pm
Hi ness no its just that panel in that project. A bug of some kind maybe?
August 24, 2014 - 6:40 pm
Hi Jim,
I loaded your project and had no problem with the nil panel.
Does this happen when you change other panels in other projects to nil?
ness
August 24, 2014 - 6:15 pm
Hi Ness thats exactly what i did but nill panel was not on that list. its normally at the top but wasnt….
August 24, 2014 - 2:14 pm
Hello Jim,
I’ve attached a zip file again to this post. Not sure why it didn’t show up in the other one.
To change the material on a drawer front, click on the set of drawers (multiple drawer, even if there’s only one) and then when it is selected, you should see the different individual drawers  in the properties menu.
select-drawer-fronts-01.jpgImage Enlarger
Click the + sign on the drawer you want to edit to open that individual drawer parameters.
This should give you access to the materials for the drawer front.
select-drawer-fronts-02.jpgImage Enlarger
August 24, 2014 - 12:46 pm
Also I dont have nil panel as an option on the drawer front, I can use nil panel on any of the other parts of the drawer but not the front as its not on the drop down list for some reason?!
August 24, 2014 - 12:38 pm
Hi Ness, not sure if it’s me but i cant see a file attached?
Guest(s) 28
2 Guest(s)
