Hi and Help please|Forum|WOOD DESIGNER
Hi and Help please
Forum Posts: 918
January 24, 2017 - 9:17 am
Hi Lloyd, thanks very much for the photos and for the detailed explanation of your project.
I’m really glad Polyboard combined with the CabinetFile service worked for you, cutting down on errors dramatically by the sound of it. We planned this alternative to buying the software outright exactly for one-off or occasional projects like yours.
1 hour to design your latest project, that’s not bad!
Thanks again, Stefan
January 24, 2017 - 6:46 am
Good morning Stefan
As promised months ago, please find attached the pictures of my first Polyboard project. Note that this kitchen projected started more than a year ago, but i would like to explain the reasons behind the length of time taken and the progress off this project. There are a few minor outstanding items as a result of my suppler short supplying the parts, but this will be completed once i find some more time in my schedule.
But first, let me start by saying, i am an amateur cabinet maker (IT Specialist by day) who does this purely as a hobby. I had undertaken small projects before but resorted to manually drawing out the plans which where time consuming and often presented calculation mistakes etc. Polyboard allowed me to accurately plot the plan, down to the millimeter. The best part however is that the software is cost effective for hobbyists as this allows you to utilize the full features without having to spend thousands of pounds on buying the commercial versions.
I started the design based on an existing layout, but utilized Polyboard to enhance the aesthetics by adding modern touches. Those being wine racks, spice cabinets, large pull out pot drawers etc. I was also able to create the spaces required for my appliances with precise measurements.
I decided to use Raw MDF for the outer facing materials but spray painted this using a 2K high gloss white coating (Highly durable and non-yellowing) instead of PVC wrapping which turned out to be to costly based on the dimensions of this project. It came out amazing but took the most amount of time to complete.
I decided to break the single project down into 3 project files by simply copying the floor and wall layout. This allowed me to navigate around the different areas quite easily with the final layout in mind. The 3D view also allowed me to get a feel of what the final product will be.
I never expected the project to turn out so amazing, but more importantly this easy. Due to this being my first project, i had to learn the Polyboard features using the online resources, but i am busy with my second project now, which literally took me 1 hour (Design entire bedroom) to complete.
Please do feel free to respond to the post if your w and cutting lists to make it all so easy.
Lloyd
20170124_064609-1.jpgImage Enlarger
20170124_064633-1.jpgImage Enlarger
20170124_064656-1.jpgImage Enlarger
20170124_064700-1.jpgImage Enlarger
20170124_065625-2.jpgImage Enlarger
20170124_065632-1.jpgImage Enlarger
20170124_065643-1.jpgImage Enlarger
20170124_065656-1.jpgImage Enlarger
20170124_065711-1.jpgImage Enlarger
Forum Posts: 918
January 25, 2016 - 7:43 pm
We further analyzed the ‘Base 450 Standard 4 Draw’ cabinet, and concluded that the current PolyBoard version (v5) was not adapted to such an extensive use of ‘0 thickness’ panels.
Nevertheless we’ve made some modifications to version 6, so this feature will be better handled in the next version when it is released.
Forum Posts: 918
January 25, 2016 - 9:18 am
We carried out several tests around this issue, and our first conclusions are that the crash is due to the ‘Base 450 Standard 4 Draw’ cabinet.
The problem is related to the use of a ‘Masonite – 0 mm thickness’ panel as drawer bottom material.
If the Masonite thickness is increased to only 0.1 mm, or if we reduce the number of drawers to 2, there is no crash.
We will analyze this further before coming to a final conclusion.
Forum Posts: 918
January 22, 2016 - 2:30 pm
Hi Lloyd, here are your files. For some reason, the second version you sent me of -stove-wall has been corrupted to the extent I couldn’t export the part by part DXF files.
I don’t think you will need them, but let me know if you do, and upload a newly saved version of that Polyboard project to the forum so I can try again. We’re taking a look at the possible reasons behind this at our end too.
All the best, Stefan
January 22, 2016 - 10:44 am
My Apologies Stefan. Here you go.
Thanks for the additional information,
Forum Posts: 918
January 22, 2016 - 9:41 am
Hi Lloyd, I don’t think the files uploaded. Could you try again.
The extra files are DXF files of the whole project and each individual part. These can be used by suppliers to run their CNC machines for example, or you can import DXF to a CAD programme like SketchUp to work on your project further.
January 22, 2016 - 6:36 am
Hi Stefan
I have re-activated my full membership and paid the membership fee. Kindly assist with the attached projects, I require the cutting lists please.
Also, i noticed that the previous documents sent to me contained a number of other files, how do we go about using these files and what are they meant for, as the file types were not recommended.
Thank you and regards
Lloyd.
Forum Posts: 918
January 18, 2016 - 7:22 pm
Hi Lloyd, thanks for the details of your supplier. We will definitely contact them.
Thanks for using our CabinetFile Lite service. Here are your files.
Please note, CabinetFile Lite is a processing service only. We haven’t checked your final designs in any way. I did notice however that you’ve used the Quick Design materials. I assume you’ve got that covered with the conversation you’re going to have with pennypinchers.
Otherwise watch the ‘Quick Design Construction Materials’ video on this page to see how to change from Quick Design materials to materials that are more coherent to manufacture:
https://wooddesigner.org/membe…..-advanced/
Good luck with your build. Please let us know how it goes (any pictures of the end result would be great if you have time to upload them), and please ask if you have any manufacturing queries.
January 18, 2016 - 11:58 am
Dear Stefan
Thanks for the reply, I will speak to my supplier about partnering with yourselves, You may also try to contact them Penny Pinchers they are a national chain so they would be a perfect partner, plus the added benefit of a free full membership would be great 🙂
Regarding the project files, please find the updated files that is now ready for generation of the cutting list.
I am aware of certain components and parts being missing which i will discuss with my supplier, so i am happy to just proceed with the project plans as they are.
Thank you very much for your assistance.
Lloyd
Guest(s) 27
Duayne Naugle: 129
Ray: 59
Patrick Maylor: 57
dziekan
AKM
Garyh
niharbu
Daniel Jones
Topics: 2075
Members: 254
