hinge placement|Forum|WOOD DESIGNER
I have moved your post into PolyBoard Section for faster management,
I let you adjust 720/740 😉
For this add
first rule at 80 – 80 with max distance of (720*3+80+80) 2320 mm or greater to be sur this first link add only 2 hinges, at 80 – 80 mm
Second fittings and rule at 720 – 720 with max distance of (720*2) 1440 mm or greater to be sur this first link add only 2 hinges, at 720 -720 mm
Hope that’s helpful,
OfflineHi Alex
thank you for getting back to me
the problem i have is that the customer is going to drill their doors 80 /740 no matter the size of the door so i need the top hinge to be 80mm down and the bottom hinge 80mm up and the middle hinges to be 720 down and 720 up is there a way to lock the position to that all the time even when the size of the door changes?
many thanks
ryan
Yes, when you create your doors you can set rules to définie top and end positioning
For exemple and for Applied Doors use rule following Overpassing panel (P)
For Bult-in doors use rule following Underpassing panel (N)
The minimum distance between 2 hinges is given as in the second screen shot by the value “distance” (here at 600 mm)
whenever the 600mm distance is exceeded between two hinges, a new hinge is added per division
