January 28, 2018
Ness said
Hi Conor,The position of the hinge plate holes are set in the hardware definitions.
In your case you are using the QuickDesign 0-hinge010/app.
This is set up to drill at 35mm from the edge so 33mm when you take off edging.
If you go to the hardware libraries and change 35 to 37 you'll get 35mm from the edge with 2mm edging applied.
Hope this is helpful,
Fantastic Ness thank you. I had changed that when I didn't have the "net dimensions" ticked in my optinest options and I couldn't remember where I made the change.
Hi Conor,
January 28, 2018
Hi all, I'm attaching a wardrobe that should have 2mm edging applied when it is machined.
So my gable hinge plate should be bored at 35mm from the front edge to finish at 37mm in when it is edged.
However it is boring at 33mm, I've tried looking at rules but I cannot figure out where to change this setting.
Help please.
Thanks, Conor
