How to add Hardware to an upright|Forum|WOOD DESIGNER
If I understand your request correctly, you can’t connect two parallel panels.
Only links between a priority and non-priority panel are possible (perpendicularly).
Andrew Driffield
Forum Posts: 5
September 19, 2023
OfflineHi, I’m new to polyboard but slowly getting to grips, I have added some hardware we use to fitting list and setting rules, I can successfully add the hardware to adjoining panels but want to add the hardware to an upright to join the sides and not the bottom of the cabinet, is it possible to do this?
Many Thanks
Guest(s) 38
© Simple:Press —
