How to create a box without back panel?|Forum|WOOD DESIGNER
Pravara Modular Industries LLP
Forum Posts: 17
March 6, 2024
May 20, 2024 - 4:46 pm
Hi Dean, Hi Michel,
I tried both the options suggested by you. cool
Thank you.
Thanks & Regard
Venugopal N.
Forum Posts: 1040
May 20, 2024 - 1:45 pm
Hi Venugopal,
There are 2 options:
1 If you mention no on the back panel before the creation of the box
2 if you mention no on the back after the creation of the box.
exclude-panel.pngImage Enlarger
in the first option, it means that all future boxes will have no back by default ( permanent setting
the second option removes the back only related to that specific cabinet (bespoke change)
Rooms Made Simple
Forum Posts: 73
September 1, 2022
May 19, 2024 - 6:21 pm
Hi Venugopal,
  I believe if you create the box WITH a backpanel, you can select the backpanel and change the material to “Nil”. This will get rid of it.
Dean
Forum Posts: 17
March 6, 2024
May 17, 2024 - 1:16 pm
I tried the same by choosing “No” for back panel while creating box cabinet.
I don’t know if that’s the right procedure or not. Thanks for the clarification.
Thanks & Regards
Venugopal N.
Forum Posts: 611
May 17, 2024 - 8:08 am
Hi Venugopal N.
I don’t think the video has attached to your post.
If I understand your message correctly, you should be able to nil panel your back, or select it not the be present. Please refer to attached image.
Let me know if you need further clarification.
IsaacForum-a.pngImage Enlarger
Forum Posts: 17
March 6, 2024
May 16, 2024 - 1:57 pm
I would like to create a box without back panel, meaning I only need two side panels, top and bottom. Depth of this box is just 70mm and I should be able to add shutter to this box.
I have attached a short video clip for your reference. In the video frame is made of aluminum. Now, I need to create a similar frame in plywood for which I should be able to add shutters.
Thanks & Regards,
Venugopal N.
Most Users Ever Online: 365
Guest(s) 21
brendan kavanagh: 168
Tom Cleaver: 164
mark nichols: 162
Conor Devoy: 158
Zaheer Abbas: 132
Blake Simpson: 104
Tom Jackson: 83
Patrick Maylor: 81
roni vilavila
Miryahya Khameneh
mathew moule
Christian Lopardo
Romerworld
Evaldas Gudenas
Petr Břichnáč
Ar Te
Ilie Mihail
GERARDO MARMOLEJO
Topics: 2480
Members: 380
