How to get a sharp corner for led strip pocket, inner tooling processing. |Forum|WOOD DESIGNER
Puuslik
Estonia
Forum Posts: 46
February 23, 2024 - 9:44 am
Thanks, now my problem is solved .
Ain
Forum Posts: 2128
February 22, 2024 - 7:56 pm
Thanks for your quick reply Joss,
You can do your groove as single panel fitting
single-panel-fitting.pngImage Enlarger
then extended it from PP setting , or extra setting with Customized tool if only for this grooves
custom.pngImage Enlarger
MITC
Forum Posts: 60
February 22, 2024 - 4:12 pm
Do it as a single panel fitting using a groove. Then you can set the post processor to extend your grooves longer.
Puuslik
Estonia
Forum Posts: 46
February 22, 2024 - 3:36 pm
Hello!
I need led strip pockets after cnc processing without the arc corners3d-visual.jpgImage Enlarger
Programming.jpgImage Enlarger
result-with-arc-corners.jpgImage Enlarger
of the blade radius.
So that the pocket extends beyond the outer line of the part. See attached pictures.
Best regards!
Ain
Currently Online: Nadeem Lotia, Isaac
Guest(s) 51
Timothy Bennett
Members: 536
