Inner tooling problem + different zero points|Forum|WOOD DESIGNER
Thank you for your response. I have got version 6 and yes, I see that new cutting options in version 7.04b respond my needs. But it is just one issue solved. Before I pay for new version I would like to be sure that I will be able to set different zero points too. Unfortunately I can not find information about that. I upload pictures so you can understand me better. Can I choose in Polyboard the edge from which my CNC with TpaCAD start measuring?
which version have you got?
Now in version 7.04b available on the download page there is a new cutting option that may respond to you needs
More information here
When I am milling a board near the edge (making rectangle by inner tooling) my CNC shows 2 ways of cutter (picture 1) but when I want milling in the middle it shows me 4 ways (picture 2). Is it possible to make in Polyboard one way of cutter instead of 4? I can not set groove mode for milling while I have also circular saw for other grooves.
My second problem is about zero points for drilling. Is it possible to set different zero points for different drillings? In TpaCAD I can change zero point by writing in text box 0 or 1 but I can not find anything like that in Polyboard.
All the best
Szymon
