Inner tooling to edge|Forum|WOOD DESIGNER
Hi Marianne,
Would you please send me the cabinet file and a copy of your post processor? I think this will make it easier for me to understand exactly what you need and I can give you an example with your set-up and cabinet. See the attached image for exporting your PP.
Please send these files to support@wooddesigner.org with the reference: Files for Isaac.
When i make it a groove like this, will the machine use the saw for this operation? Or is it possible for me to select milling 8 mm for it?
Also my cabinet is a bit different from the one in your example. I have the doors built in (underpassing) and a “long” carcass/bottom-panel. See image
So I ajusted the panel door to “underpassing” and face to “face2”, but the last pocket that was suppose to go to the second door-corner is now placed way off because of the long bottom-panel-measurement.
Hope I explain it okay. On image 3 the pocket is perfect placed but the second one is way off
September 29, 2021
Hello!
I´m trying to make a pocket for a fitting placed at the corner of a panel. Since the edge tooling wants to process the whole edge (and I cant seem to find a parater that allows me to enter pocket depth), I though I could apply an inner tooling.
Since the pocket-dimensions I want is just 4 x 25 mm (depth 13 mm), and the tool it will be milling with is 6 mm, I made a pocket of 8 x 29 mm and set the position to -4 mm.
When I do this I get an error-message on the machine (Homag drillteq200) referd to the contouring.
This seems to be an easy task for the program/machine to do, so is there a different way to do this?
BR Marianne
