is there a way to build a full size cabinet and split into sections |Forum|WOOD DESIGNER
May 8, 2025 - 8:22 am
Hi Ben,
ben levene
Forum Posts: 69
May 7, 2025 - 4:24 pm
here is one that i would have to split up manually
April 28, 2025 - 1:33 pm
Hi Ben,
I think that I do have a faster solution for you.
So i properly understand what you are trying to do, can you please send me a project with some cabinets where you would like to do this? I will use these as an example and send you a video.
ben levene
Forum Posts: 69
April 28, 2025 - 1:16 pm
hi i am wondering if there is a way to build a large cabinet like a wall of wardrobes and then split these into sections? at the moment i build the cabinet as one but then i use the measuring tool to define what sizes each section is and then go and make a new cab and then add them all together in project mode. just thought asking the question could have a quicker solution for me but not expecting the answer to be yes.
Guest(s) 32
