issue with drawer runners|Forum|WOOD DESIGNER
June 23, 2026 - 8:45 am
Hello Caroline,
Yes, if the cabinet you attached below is having these problems, then you can make a separate rule and apply it to only the drawers that need to move by 14mm.
brendan kavanagh
Forum Posts: 229
June 22, 2026 - 4:53 pm
Hi Isaac
Sorry was not in the office for few days
Thanks for the video makes sense but i think i forgot to mention the bottom runner is ok its the ones above that need to go up 14mm do i need to make 2 rules?
Thanks Caroline
June 17, 2026 - 10:48 am
Hello Caroline,
I hope that you are well.
See the following video, and let me know if you have any further questions:
brendan kavanagh
Forum Posts: 229
June 16, 2026 - 4:57 pm
Hi
Could you take a look at the attached unit, there is an issue with the position of holes for drawer runners,  the drawer fronts are handless so gaps you can see in unit for opening
Runners don’t seem to be up high enough to clear drawer fronts, we have to redrill the holes 14mm up for runners/drawer fronts to fit properly.
Can you let me know
Thanks Caroline
Guest(s) 34
