Lamello Divario for nesting CNC|Forum|WOOD DESIGNER
Rikka
Amsterdam
Forum Posts: 44
October 16, 2022 - 12:16 am
Brilliant, that’s all sorted! Thanks so much.
Best,
R
October 15, 2022 - 5:23 pm
Hi Richard,
As far as I can see you need the first hole of 8 mm at 44 from the front and back of the shelf with a second hole at 32mm distance. I made a hardware fitting for the holes with a rule to fit your need on the attached cabinet.
Whatever recess value you apply on the shelf the rule will follow it at all times independent from the cabinet.
You can just restore them to your libraries. Let me know if this is ok for you
Rikka
Amsterdam
Forum Posts: 44
October 15, 2022 - 4:10 pm
Hi.
I’m hoping to write in fitting link for when I want to use the Lamello Divario. The panel edges will be done by hand with the Zeta P2 but it would be great to have the CNC already drill the required 8mm holes.
It is a pair of 8mm holes 10mm deep with 32mm spacing. Please see detailed info via the link below:
https://www.lamello.com/filead…..150302.pdf
They would need to reference the shelf front and back rather than the cabinet itself.
Any help greatly appreciated! Thanks
Best,
Rich
Most Users Ever Online: 704
Guest(s) 87
brendan kavanagh: 198
Conor Devoy: 158
Zaheer Abbas: 152
Patrick Maylor: 108
Emmanuel Sacco: 106
Blake Simpson: 104
Nathan Bruton
Michael Okyere
Timo Pitkänen
jose andres durango medina
Dag Lislerud Midtfjeld
Rejmond Islami
juan cabezas
Michael Dyer
ALEJANDRO PALACIOS RODRIGUEZ
David Filiba
Topics: 2697
Members: 463
