Machine Orientation|Forum|WOOD DESIGNER
Machine Orientation
July 15, 2025 - 9:06 am
Hello Zaheer
A WoopWOP MPR PP can vary depending on the machine and set-up that you are using. See the following:
1. Optimization mode: The options 0 through 4 typically refer to different levels or types of toolpath or machining sequence optimization, especially relevant when multiple operations are present.
2. The original position of your panel, dependent on your machine.
3. On the fly code: “On-the-fly code” refers to machine-level CNC instructions that are generated dynamically at runtime or inserted directly into a program. Commonly used with macro machining functions.
4. Sort tooling’s: The order in which your toolings output in your files.
These are usually specific to your CNC. For further information and advice, I recommend discussing these intricate details with your WoodWOP support.
Zaheer Abbas
Forum Posts: 178
July 15, 2025 - 8:32 am
Hello again, I didn’t realize the photo didn’t upload, and I’m not able to add it even though it’s only 180KB. Anyway, I wanted to ask about the ‘Machine’ section in the postprocessor settings — like optimization mode, panel origin, on-the-fly code, and sort tooling.
July 10, 2025 - 8:09 am
Hello Zaheer,
Can you please clarify what you are asking for?
Zaheer Abbas
Forum Posts: 178
July 10, 2025 - 5:52 am
hello , can you please explain to me how each one of these options affects the piece orientation on the machine?
Currently Online: Keith Shelley, LORIN STANCIU
Guest(s) 114
Javier Velázquez
sjust
Topics: 2933
Members: 554
