The last version of PolyBoard is 7.09a,
First of all, I recommend to make a backup
https://wooddesigner.org/help-.....-settings/
then you can follow this instruction
https://wooddesigner.org/help-.....-software/
I can not open MITC file
polyboard say unexpected file format
my version is 7.08c
last night I work on it too I have to test it before I let you know if it works
i use split panel and different toolling.
it looks it working
I just go 1/8” inside and I saw people they do only one side and the door does not move
I come back with my results
thanks again Alex and joss
Hi Joss,
Thank you for this very interesting solution,
Yes, I have already done this type of doors,
You can model in PolyBoard, but I'm not sure it makes a pocket,
Of course, it will be necessary to use high-density MDF, and to remove the same thickness from the front as from the back in order to avoid any difference in strength between the front and the back.
My first mistake was to make only one side and when I painted it, it became deformed
However, the easiest way to do this is usually to process it directly through the CNC software
Hope that's helpful, Alex
June 3, 2017
Hi Alex,
did you had any experience to make these doors with polyboard
They make it on mdf. It call shaker door
https://www.pinterest.ca/pin/8.....520402089/
Thanks,
mehrdad
