I haven't got your Libraries, but I think Polyboard can't apply modifications due to specific editing (materials and structures?!).
But if I am not mistaken when you created a new cabinet with these methods it does not give this problem,
if you upload a backup of the library (in Zip) can I see which sub-method does this and send the request to the developer
Cheers, Alexandre
May 18, 2014
I have created various standard cabinets that we manufacture. By selecting manufacturing methods I would like to change the cabinet to a different specifications. For example, if the standard cabinet is made from 18mm egger with 18mm MDF faceframe with associated divisions and doors etc, and I now want to change the spec to 19mm veneer with a 22mm solid wood faceframe with associated divisions and doors, I would select the manufacturing method that I have set up for this method. However when selecting another method, polyboard crashes and shuts down.
I have tried this selecting various different manufacturing methods and all end in a shut down. I am able to change each of the manufacturing fields individually, but not as one through the manufacturing method.
Any ideas to what is going wrong?
